Surface Fill - Change appearance
Hello members, is it possible to change appearance of Surface fill to other color?
kdirth
kdirthAnswer
I don't believe there is a way to set the color before creating the fill other than to give the model a specific color.  After creating it, select the surface on the screen then select a color from Appearances.
yes, apply an appearance to it:
umg10-MarbleAuthor
Thanks for reply, but when I select Fill feature and Go to appearance then Edit  Model appearance is greyed out. Any other way to do that?
kdirth
kdirth21-Topaz IAnswer
