Surface finish symbol attached to the surface in Creo Drawing
Hello!
How do I add the surface finish symbol onto the surface that needs to be machined?
Desired symbol is Ra 3.2 (machining required, all around).
Best regards,
Sergey
Type in 3.2 as shown in below snapshot. Otherwise create a free Note "Ra 3.2" and relate it to view.
tbraxton
Under the annotate tab select surface finish and in the placement tab select the on entity option.
http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/detail/symbols_surf_finish.html
Sergey15-MoonstoneAuthor
This command is insufficient as it miss what I am asking for.
