Surface to solid model
  • November 28, 2011
  • 3 replies
  • 21596 views
Hi, I am looking to convert a model that I imported from a step file to a solid model. the model when imported consists of all surfaces. All the surfaces are fine in part checker. My main objective is to modify the part and it wont allow this as a surface model. Any help on this would be greatly appreciated. Ps using Creo elements/direct modelling
Edit definition on the import feature.
Then activate the Import DataDoctor.
Check the model tree and make sure all the surfaces are Combine. Shift select all, RMB, Combine. Then I will select the combine, RMB, Collapse.
That will put all in one set. Then you can start fixing bad areas.
Hi Niall...
I'd suggest posting your question in the Creo Elements Direct forum. Mike Minsterketter's advice is for Creo Parametric, Creo Elements Pro, and Pro/ENGINEER Wildfire. The "IDD" (Import Data Doctor) is used in those packages.
In most cases, Pro/E and Creo try to "heal" imported geometry into a solid automatically. Sometimes when there are mismatches that the system cannot account for, you can perform microsurgery on the part to resolve the errors and create a solid. Since the early days of Pro/E, this process was sort of a hidden art. The latest versions of the main Creo Parametric and Creo Elements/Pro software does a much nicer job. However, the process still requires a bit of skill.
But again, that's just for the basic software. You're using Creo Elements Direct (formerly Co-Create) so there's likely an entirely different process. The users in the Creo Elements Direct forum will be much more helpful.
Try posting your question here:
http://communities.ptc.com/community/creo-elements-direct/modeling-express-english
Thanks!
-Brian
Thanks very much for the help guys, will ask in the correct forum. Appreciate the time. Niall
