Feb 9, 2011 1:46 AM UTC
Surfacing in SW vs Pro
There is a movement afoot at this company to replace Pro with SolidWorks. I am the only one who really does any surfacing around here, so I need to make sure that I'm not going to get screwed by this change if it goes through. I heard years ago that SW could not do complex surfacing, but I've seen stuff out there that would lead me to believe that this has changed more recently. I have very little experience with SW and that is only on rudimentary shapes.
Can anyone give me a comparison on the current surfacing capabilities of SW vs Pro. Is there anything it cannot do (or does poorly or is much more difficult)? Sweeps, Blends, Helical sweep, Boundary blends, Variable section sweeps? Trajpar capabilities, surface tangency and continuous curvature control?
Please limit this comparison to capabilities and not opinions or SW bashing 🙂
Jeff
Feb 12, 2011 2:01 PM UTC
Hi Jeff,
I was on the SolidWorks team with Bart during the shootout, and have written a follow-up article to the event:
Bart is a hard core Pro-E user, so he is not likely to overstate SW surfacing capabilities as he currently teaches more Pro-E surfacing classes than SW surfacing classes.
Before using SolidWorks, I had started on Pro-E as well. My suggestion is to take a Pro-E model that is typical of the surfacing modeling you do, and have the model recreated in SolidWorks for comparison. Some of the SolidWorks surfacing tools will be different as SW does not have the Variable Section Sweep (VSS) or the ability to create conics (w/ rho value). However, SW has a few surfacing tools, such as the "fill" surface, not found in Pro-E (Pro-E's fill tool is similar to SW's planar surface tool), and it does not require purchasing and additional add-in, such as ISDX, as it is part of the core package. The boundary tool in SW allows C2 along edges in both direction 1 & 2, and the fill tool allows C2 on all contract edges if the surfaces are well constructed.
On the downside, when saving a SW file with surfacing, it is almost twice the size of a Pro-E file (example: Pro-E file 1 MB --> SW file 2MB). However, the housekeeping is better in SW as construction surfaces can be removed by using a "delete" body tool, and SW has solid & surface body folders that make it easier to locate individual surface & solid bodies in the model / feature tree.
I would suggest waiting until Creo is available and test Creo and get a pricing of the different Creo packages. In the meantime, have a Pro-E part remodeled in SW and compare it feature by feature to the Pro-E model. You could even request a 30 day license from your local SW VAR.
Chris Thompson, CSWP
Appian Way Technologies LLC
Powell, Ohio 43065
www.appianwaytech.com
(614) 595-3751
SW Premium 2010
Pro-E WF 3.0 (including ISDX)
In Reply to Jeff Sampson:
Jeff
