Swept blend missing sections tab
When I go to do a swept blend I select the sketch to be the trajectory. When I click the Sections tab next to the references tab, the normal menu where I can select or sketch sections does not appear; the tab does not lead to anything. It once worked, and now it does not appear. This happens while trying to create a new swept blend, and on parts that have existing swept blends I can no longer edit the sections because this tab leads to no menu. Is there a solution to this?
    Resolution (CS218107)
    Mahesh_Sharma
    22-Sapphire I
    August 7, 2018
    Check old post for the same Re: Placement disapperaed
