11-Garnet
May 21, 2024 8:52 AM UTC
Symbol to show Part parameter in assembly MBD
I am trying to add BOM index and other part parameters in 3D MBD in creo.
As Creo does not provide parametric tables, I am creating some parameters inside parts and want to show in the symbol attached to part.
When I tried to use note with parameter, &description:att_mdl, it showed part level information.
But if I add it in symbol, this does not work. If I add &description:mdl using variable text, it shows the assembly description, not part description where it is attached.
Please let me know if anyone have any other workaround or solution.
Emeritus
May 27, 2024 10:16 AM UTC
Hi @Vinayak_Patil,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
8-Gravel
Jun 10, 2025 10:41 AM UTC
I face the same challenge.
When i want to show some parameters like part weight, part name, material etc in MBD , i am able to do that using "&param" if i use inside a note.
But, if i use the same syntax "&param" inside a symbol like title block , then it is not working.
please some one advice would be very helpful.
