Jul 30, 2012 7:26 PM UTC
System & Model Parameters
How can I effectively link model parameters to my system parameters on templates/formats that I create? I need the model parameters to transfer to my drawing template on my BOM and Title Block, and I cannot figure out how to successfully link the two so that whenever I do need to create a drawing and I insert a part onto that template, all the information is there.
Jul 30, 2012 9:11 PM UTC
Hi Kenan,
I will give you a exemple how to do it with a parameter created by you, but remember that Creo or pro/e has some internal parameters that you can use.
1º Create a parameter on your part named "123" and give him a value number or string etc.
2º In your drawing template create a note with this &123 .
The "&" symbol is to call a part parameter.
If you have more doubts just ask.
Hugo
Hi Kenan,
Hugo
Jul 31, 2012 2:03 PM UTC
Hugo,
Thank you! It worked, and makes perfect sense. I have one more question. How can I create a standard parameter list so that each time I create a part, that same list comes up? As of now, every time I design a part, the parameter list resets. I don't want to be wasting my time every time I design a part just in rewriting the parameters. Any help would be fantastic!
Jul 31, 2012 2:08 PM UTC
Kenan,
You can create a part template with all parameters that you want. Everytime you start a new part you choose from your template. You can create parameters, planes, coordinate systems...all that you want. Since you are starting a new part those parameters are empty but they are already there.
I hope this answer your question or i am not understanding your issue now.
Hugo
Nov 8, 2013 10:01 PM UTC
guys, new to CREO here, where can i find a list of default parameters like "&pro_mp_mass". it was much eesier to find back in WF.
thank you
Carlos
Jun 23, 2016 8:57 PM UTC
There is some information in the help files, and there is a drop-down in the lower right corner of the Parameters window that you can switch to show reported and alternate mass property parameters
Reported and Alternate Mass Property Parameters
About Working with Mass Property Parameters
