May 4, 2010 5:20 PM UTC
Table question in drawing mode
I have a drawing sheet with an exploded 3D view of an assembly and balloons linking it back to a customized BOM table. I have also created a second general view of the same model that is a left side sectional view, on the same sheet. I want to show the same balloons referencing back to the same table, on both views. In other words 2 balloons per component, one on each view. Anyone know how I can do that?
May 4, 2010 6:19 PM UTC
You'll prolly have to buy Solidworks. Just kidding. I have no idea, but I couldn't control myself.
May 4, 2010 6:30 PM UTC
Well, using Wildfire means I could probably make the transition pretty easily.
May 4, 2010 7:32 PM UTC
This is not a pretty solution, but you could place another table outside the border and put a repeat region on that one to balloon from it as well. You must make sure that both tables match each other or your find numbers will be wrong. The only other way to multi balloon a part is if that part is used more than once in the assembly. Oh and watch out for those big assemblies in SolidWorks. Regards Eric
