Text orientation for dimension on drawing
I want to rotate this values as vertical. Could you anyone help me ?
tbraxton
Have you followed the techniques presented in the documentation?
To Change the Orientation of a Linear Dimension
You can change the orientation of a linear dimension that is created using any of the following entities as references:
•A single linear entity.
•Two explicit point entities.
•Center or any tangent point of any two circles, arcs, or ellipses.
•An explicit point and a center or any tangent point of a circle, arc, or ellipse.
The orientation is not active. How can I do active the button?
please publish a picture showing requested state. You can use Windows Paint application to create such picture.
