The instruction to create a multi line section view
Hi all
What are the instructions to create a multiple line or inclined section view. Should I always create a reference plane in the model first ? Or is it possible to sketch directly in the the corresponding drawing view?
kdirth
I believe you are tying to create an Offset Section.  In the model, go to the View tab and select Offset from the Section drop down menu.  Select a plane normal to the desired section and sketch lines as needed to created desired section.
