6-Contributor
The issue of automatic loading of drawing format files
Can I set priority to loading format files in the same folder as the drawing, instead of loading files in the format folder specified in the configuration file?
having the same format stored in duplicate in different directories makes no sense.
Can you explain what it is you are trying to do?
The formats are loaded with the drawing templates, no need to select any format.
