the "OK" selection of edit dimension properties is greyed out
  • December 20, 2016
  • 7 replies
  • 3829 views
Trying to edit the properties of a dimension but the "OK" button is grayed out.
I still have a copy of the file when it was last saved in Wildfire 4.0 and when I open in Wildfire 4.0 there is no issue with editing the properties of any of the dimension.
When I open this same file in Creo 3.0 some dimensions I can edit the properties of and some I can not because the "OK" is grayed out).
I cleared out any system and user config.pro settings to make sure there was nothing in them that could be causing the issue.
Any thoughts of what could cause this?
StephenW
If this is in the drawing and pdmlink is active, possibly the part file is locked but the drawing is not. Dimensions shown are not editable and dimensions created are editable.
That's all I got.
Its actually in the model that this is happening. I even saved it out of Windchill and tried opening it unassociated to Windchill and have the same issue.
The user actually just pointed out that it is only angled dimensions that the "OK" is greyed out.
2-Explorer
December 20, 2016
What do the dimension properties look like?
