This Error appears to me every time when i want to add helix ''invalid accuracy combination, cannot generate/modify part more accurate than profile'' how can i fix it?
  • September 30, 2016
  • 4 replies
  • 1926 views
I am working in PTC creo Elements/Direct Modeling 6.0. This Error appears to me every time when i want to add helix ''invalid accuracy combination, cannot generate/modify part more accurate than profile'' how can i fix it?
What should i do?
Hi Alexis,
if you want to work on a part with the standard resolution "1.0E-6 mm" (see part property) with a workplane ( supose you  imported geomery) with resolution eg. "1.0E-4 mm" (see workplane property) it will not work.
Either you down-change the resolution of your part in part properties to the resolution of the profile/workplane or you re-draw the profile in a new workplane in the resolution of your existing part.
I would suggest the 2nd.
Parts with lower resolution in your constructions will cause problems in the future.
Good luck
One trick I have found, if you are working with an imported model, create the workplane without referencing the imported model and prior to projecting any 2D from the imported model, draw a line. This will keep the accuracy of the workplane at 1.0E-6 mm. The projected 2D may require some trimming to clean up the vertexes.
Unlike parts, I found that I could increase the resolution of a workplane.
akoulidis1-VisitorAuthor
Thank you very much!!
