Tool BOM with bulk parts
Hi All!
I am trying to open an existing solid tool (assembly) with bulk parts for the inserts and screws (I don't want to model them separately) in the NC assembly environment , My problem is, that Creo doesn't recognize the proper quantity even though the BOM_REPORT_QUANTITY parameter is already set.
Also, can I use a parameter to override the type field to show INSERT / HOLDER instead of GENERIC?
Is there any workaround for this? Thank you!
I am using Creo 12.
Community Moderator
Hi @VW_13931977,
Thank you for your question.
Anurag
Thank you!
Unfortunately it seems, there is no solution 😥
Lets hope Creo 13 will fix this issue! 😁
Viktor
