Sep 8, 2015 12:38 PM UTC
Toolbar "Table" delay
Dear all,
      using Creo 2.0 M100 and every time I'm working on a drawing model, when clicking the first time on the toolbar "Table" (to perform a baloons creation, repeat region operations, etc...) I must wait at least 15 seconds before to start typing some other commands. The mouse pointer remain in loading status for an unidentifyed reason.
This is not a big problem but of course a waste of time that with ProE WF2.0 we didn't experienced before. Is someone having the same "disturb"? Do someone knows how to set off this issue?
Thanks in advance
Fabio
Mahesh_Sharma
22-Sapphire I
Sep 18, 2015 12:16 AM UTC
Fabio,
In addition to information from Amit, check earlier post Creo goes to not responding mode after click on Table menu
It may have some information of your interest.
18-Opal
Sep 10, 2015 3:56 PM UTC
Hi Fabio,
I have seen other customer issues, with a delay after activating the Table or Annotate tab.  The issue could be cause by an extremely large number of tables or annotations that need to be updated or it could be a drawing specific issue, where this is some slight corruption in a particular area of the the drawing, that causes the delay.
If you are NOT seeing this issue on all of your drawings, it could be drawing specific and perhaps opening a Tech Support Case and providing the files, would help.
If you are seeing this on ALL your drawings, you could try on another machine, to see if the issue is specific to your machine.
If it is, then I would suggest checking the graphics card and driver version for your machine configuration, to verify that it is certified or supported.  You can find this information on the Platform Support page; click on the By Product drop down and select your product, e.g. PTC Creo 2.0.
Amit
Mahesh_Sharma
22-Sapphire I
Fabio,
Oct 12, 2015 12:03 PM UTC
Thanks Mahesh,
now the "waiting time zone" is disappeared.
Regards
Fabio
