Dec 21, 2013 5:56 PM UTC
Tooth space milling
I have made an assembly composed of a gear and hob with gear mechanism (see attachment).
Now I want the hob to remove the material continously when it intersects the gear blank.
I would really appreciate it if anybody can help me.
Best regards
Emanuel
Dec 21, 2013 10:11 PM UTC
Hello Emanuel and welcome to the forum.
I am going to make two assumptions which you can clarify.
1. You are not using the manufacturing extension
2. You want to show the material removal as an animation
If you only wanted to make the cut, obviously you can do this in many ways, even at the assembly level by making an assembly cut.
To make this an animation, it is more problematic. The difference is that you will be changing the gear which requires regeneration between frames.
Let me know if I'm on the right track and we can look at options.
2-Explorer
Dec 22, 2013 4:18 AM UTC
Making the cuts continously is going to end up as an approximation. Intersecting the cutter with the blank at closely spaced steps may be close enough. What is the desired outcome?
Animation of step-by-step cutting is easy enough - either create a trail file that saves a frame after each cut or drive it from AutoIT or similar scripting tool.
Dec 22, 2013 10:19 AM UTC
Above all I want to show the material removal as an animation, but I also want create the true tooth geometry without any gear software.
I have already tried the step-by-step method, but the result is a more ore less rough tooth surface:
Thank you for the hint with AutoIT.
Best regards
