Jun 20, 2022 2:12 PM UTC
traceback.log
I am using Creo Parametric - Release 6.0 (connected) Release 6.0 and Datecode6.0.3.0
i have a one question. We have a customer Stakotra Manufacturing (customer number: 134130) and they have a problem with assemblies with fatal error. When he open the main assembly, then he open part, he check the mass properties in the model, doesnt change anything. Then he close the part and see main assemby, Creo regenerate assembly and then Creo fall down. I have a traceback.log (in attachement). Do you can check the file? I am was try relative and absolut accuracy, mass_properties_calculate as automatic or by request, but the reasult was the same.
Thank you
Here are the errors that I faced
traceback.log
durgelaAnswer
Jun 28, 2022 7:15 AM UTC
Creo crashed due to an unsupported graphics card. It's already solved. Thank you
Jun 21, 2022 6:59 AM UTC
Your customer experiences crashes when the session returns to the top assembly and Creo leaves a tracebak.log file.
To help and decipher a little the log, you can refer to this article : https://www.ptc.com/en/support/article/cs232360
If you confirm this is model related (does the issue happen on all workstation?), you can randomly try the dtl option: update_solid all. It is documented here: https://www.ptc.com/en/support/article/cs31562
Now if you need PTC to perform an analysis of the log, you will need to create a Support Case with your PTC account (you can file it on behalf of your customer); https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
durgela12-AmethystAuthorAnswer
