3-Newcomer
Trayback error as shown below when using mapkey
When using mapkey dw, the following trayback error occurs
<Stored map key content>
mapkey dw @MAPKEY_LABELdwg file;~ Select `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Close `main_dlg_cur` `appl_casc`;~ Command `ProCmdModelSaveAs` ;\
mapkey(continued) ~ Open `file_saveas` `type_option`;~ Close `file_saveas` `type_option`;\
mapkey(continued) ~ Select `file_saveas` `type_option` 1 `db_560`;\
mapkey(continued) ~ Activate `file_saveas` `computer_pb`;\
mapkey(continued) ~ Select `file_saveas` `ph_list.Filelist` 1 `d:`;\
mapkey(continued) ~ Activate `file_saveas` `ph_list.Filelist` 1 `d:`;\
mapkey(continued) ~ Select `file_saveas` `ph_list.Filelist` 1 `CAD-DATA`;\
mapkey(continued) ~ Activate `file_saveas` `ph_list.Filelist` 1 `CAD-DATA`;\
mapkey(continued) ~ Activate `file_saveas` `OK`;~ Activate `export_2d_dlg` `OK_Button`;
Here are the errors that I faced
!playing mapkey dw
!%CW Unable to write to this location.
!%CWDetail view "A" on sheet 1 There is no geometry serving as the source.
please answer following questions.
1.] what Creo Parametric version do you use ?
2.] what does your mapkey do?
tkim-33-NewcomerAuthor
3-Newcomer
    : Creo 7.0.5.0
    :Save as dxf on a specific folder
I created and tested working mapkeys using my Creo Parametric 7.0.5.0 installation. See attached config file -AND- video.
I do not know why Unable to write to this location. message displays during running of your mapkey.
