Trouble printing zoomed view to large format (A1)
I am using Creo Parametric - Release 4.0 (connected) 4.0 M080
We are unable to print a view of a drawing enlarged to A1 paper for inspection. What settings need to be done to achieve this ?
Here are the errors that I faced
We do not get the wanted section in the print preview window.
StephenW
For me, its usually just going thru my typical print process but making sure I change the "plot" option from FULL PLOT to BASED ON ZOOM. I usually have to adjust the zoom or the screen position of the desired geometry since Creo tends to unexpectedly offset to the right.
Hi @berny2U,
Can you check if the below method helps?
Let me know your observations.
Deepak
berny2U13-AquamarineAuthor
Hi Deepak
Thank you for the video 😉
We are working on an update to Creo 8.0, I will check if this is still an issue there.
Regards
Bernard
