Mar 30, 2015 12:13 PM UTC
Trouble with offset cross sections...
Anyone else seen issues with offset cross sections from older model/drawings AFTER they have been redefined/converted to the latest CREO 2 mode? I have inherited an older drawing of a cylindrical model with an offset cross section; just two different bolt patterns, so the offset isthrueach and thecenter. The drawing has a side view with an FULL(Aligned)cross section in it thatwas displaying just fine.UNTIL, I went in to define aNEW cross section in the pre-Creo model, whichcaused all the cross sections to be redefined to the new CREO mode. NOW, the offset cross section will not display. It will not show in 3D in the model, andwhile it will show cross hatching in the view, it shows a full side view, no interior section lines. I have tried to recreate theview and also taken the model to a new drawing and tried, niether worked. I have seen issues witholder drawings and FULL(Aligned) views in the past, but have always been able tocreatea new view with thedesired cross section and then simplyswap items to the new view. This time, nothing seems to work...
Any ideas? Comments? Suggestions? View tutorial pages? Anything?...
thanks in advance...
8-Gravel
Jul 27, 2015 4:56 PM UTC
Paul,
I have been having this exact same problem with Zero luck.
Have you found a solution since you posted this?
I have tried moving my cross section lines off of tangent points in round objects (this has worked sometimes) with now luck.
Jul 27, 2015 6:40 PM UTC
I have see issues with cross sections not showing properly in the past before Creo, so I don't know if this is strictly a new issue or related. In those past instances sometimes changing the accuracy would fix the sections to display properly. Other times I have been able to move the location of the section slightly (like 0.005") and that corrected things. Don't like doing the later if the section is to be exactly thru the center of a feature, but it is just a section and not changing geometry. Good luck.
Jul 28, 2015 12:06 PM UTC
I've done what Mark has as well. It's usually when the cross-section goes through an axis. Move it .005" away from the axis and it should work properly.
