Turning Area Cut parameters
Hi
I am finding using the new area cut for turning interface a bit confusing, while the general operation is far more simple to use from the old turning interface, get the cut to behave correctly with the parameters can be a bit confusing, I am finding that parameters that control the roughing operation entry angle, don't control the profiling operation entry angle.
What I Would like to know, is there a defined list or document of all parameters that control Area cut functions , and how to set them up correctly.
Thank you
Peter
