Dec 16, 2015 2:15 PM UTC
Two requests for improvement.
Quick access to drawing (.drw) that has the same name as the part / assembly.
Quick access to new drawing (.drw) with the same name as the part / assembly.
I tried to do with mapkeys and is not possible.
There are scripts in WWW, but should provide it PTC
Dale_Rosema
Dec 16, 2015 2:37 PM UTC
If you are asking for product improvements, you may want to fill out two product improvements with your suggestions. That way others can vote on the idea.
Thanks, Dale
Dale_Rosema
Thanks, Dale
Dec 16, 2015 3:48 PM UTC
thanks for the help.
I changed to the section of ideas.
Dale_Rosema
Dec 16, 2015 4:21 PM UTC
... and here is a link to the product suggestion:
Dec 16, 2015 5:58 PM UTC
The files as mentioned for the product request
Dec 17, 2015 11:28 AM UTC
I will try to use your programming. 🙂
Thank you
