UDF Editing
Hi all,
I have a UDF that is a sketched hole. All I am trying to do is edit the sketch to change the angle from 60 degrees to 65 degrees.
How can I modify this sketch? I know I can modify it on the fly, but I want to revise this UDF so when other people use it they don't have to modify the dimension on the fly.
When I go into the UDF Library and choose modify, there is no way for me to modify the original sketch. Also, I can't add the 60 degrees as a dimension on the family table.
Hello
May I ask which cad program you are using?
If it is Creo x or another Creo Parametric related, then you are here in the wrong forum.
Here you are at Community Creo Elements Direct in the Modeling subsection.
Have a nice day
Hello
Have a nice day
tbraxton
1) Confirm what version of Creo parametric you are using
2) Confirm if the UDF you want to modify is a subordinate UDF or standalone
3) If you do not know the difference in the UDF types then start here:
https://www.ptc.com/en/support/article/CS46583
To execute your objective you must be working with a subordinate UDF.
