Unable to find IBL file
I exported an .ibl-file for a turbine blade from CFturbo. The file is created and I can see it in the explorer, but I cannot import in Creo. The file is not shown in the import window of Creo. Any help would be much appreciated.
tbraxton
tbraxtonAnswer
It seems that it is your file naming of these files that is the issue. I was able to rename one of the files to "test.ibl" and it imports as expected. Rename the files and test them, use a simple name for testing without special characters.
tbraxton
How to import a .ibl file in Creo.
https://www.ptc.com/pt/support/article/cs107337
I am unable to open the link because I am only using a Student version of Creo.
tbraxton
KenFarley
When you attempt to open the file, did you change the Type in the dialog to .ibl File? Creo doesn't automatically show you every type of file it will read, it defaults to its own file types (.prt, .asm, etc.) If you want to read in a STEP file or IGES, or in your case IBL file, you specifically have to indicate as such in that little drop-down menu.
I set the dropdown menu to "show all". I added the file in the attachment. Maybe there is something wrong with the file?
tbraxton
tbraxton22-Sapphire IIAnswer
