3-Newcomer
Unable to save Feasibility study to model tree
I am using Creo Parametric Release 12.4 and Datecode12.4.3.0 I am building a parametric model derived from an anatomical scan of the lower leg to generate a custom orthosis, with the goal of regenerating the model when the input scan changes. To define a specific point on a curve within this model, I am using a feasibility study in the BMX (Behavioral Modeling) module. The study runs successfully and returns a feasible solution, but the checkbox to save the study as a feature in the model tree remains grayed out and cannot be selected. I have successfully saved a similar feasibility study as a model tree feature in the same model previously, using the same approach, so I do not believe this is a configuration issue. The behavior appears to be specific to this study. Software version: Creo Parametric [12.4.3.0] OS: Windows 11 Could you advise on what conditions must be met for the "save to model tree" option to become active, and why it might be grayed out despite a successful feasibility result? Here are the errors that I faced 16:18 Optimizing... 16:18 Completing step 3 of optimization. 16:18 A feasible solution has been successfully found.
Van_AG
Van_AGAnswer
Creo 8 does not allow to save an optimization/feasibility result as a feature if there is already an optimization/feasibility feature in the tree. Perhaps this issue is still present in Creo 12
Therefore, suppress the previous feasibility features, save the new feasibility, and restore the suppressed feasibility features.
Van_AG
Van_AG15-MoonstoneAnswer
3-Newcomer
This worked, thank you!
