Sep 11, 2018 1:30 PM UTC
Unblanked Object Not Showing Up
Good morning,
It seems that I am having an issue with just one single part not wanting to show up when I unblank it. The rest of the unblanked objects had no issues. Is there a specific reason for this?
StephenW
Sep 11, 2018 1:41 PM UTC
First, copy/paste of images in the forum doesn't work even tho it makes you think it works when you do it.
Could it be that the part is in a blanked sub-assy or the sub assy is blanked and not the part. We've had that difficulty in the past.
KenFarley
Sep 11, 2018 4:50 PM UTC
Another possibility, though I'm just guessing here, is the part being unblanked might be just barely intersecting another part. If that's the case and you are working with no hidden line views, Creo will sometimes just think the entire part is not visible and not show it. Seems to be more prevalent in situations where the intersection is very small, probably due to the floating point math involved?
