Uninstall thumbnail viewer for Creo 4 not working via silent working
I am using Pro/ENGINEER and Creo Elements/Pro Release Wildfire 4.0 and DatecodeM140
Uninstall thumbnail viewer for Creo 4 not working.
I copied the Thumbviewer_32_64.msi to local C drive folder and executed below command
C:\tmp\Thumbnail_PlatformServices>msiexec/uninstall C:\tmp\Thumbnail_PlatformServices\Thumbviewer_32_64.msi/passive
same way I need to uninstall for Creo 6 and Creo 8.
The main intention is to uninstall in silent mode all non-latest versions of Creo
Dale_Rosema
Are you running several different versions of the software on one machine?
If so, do you have separate installation folders for each version so that one is not trying to update the other.
I am not an expert in this, but you will run into issues if they are not kept separated since some of the supporting files will have the same name for the newer versions of files.
Community Moderator
Hi @AB_10736884,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
