Unintended dimensions updation
Are you facing unintended dimension changes for below scenarios?
| Sl No | Scenarios for Dimension change discussion |
| 1 | Wire length not matching between Table and Layout dimension |
| 2 | Deleting and re-routing the wires |
| 3 | Disassembling & assembling the same connector/s |
| 4 | Updation of Spools & wire gauges |
| 5 | Regeneration of flattening causes unintentional dimension changes |
| 6 | Adding or deleting a wire |
| 7 | Adding or deleting a bundle |
| 8 | New location added in existing network path segment |
| 9 | Change in network path at particular location, other dimension also gets affected which are not intentional |
| 10 | In flattening process, modifying branch out angle of 1 branch, leads to dimension changes in nearby branches connected to he bundle. |
| 11 | Deleting and adding the tape in same location |
| 12 | Deleting a particular portion of harness and reflatten, the dimensions are getting changed in other location (unintended location) |
