Unpattern & Make Independent
I am using Creo Parametric Release 9.0 and Datecode9.0.3.0
I am trying to unpattern a patterned group and make all the features independent of each other but I can only find "make independent under the model, operations, ATB menu which doesn't seem to work. Can you please help.
I have had a look at the rules for patterning groups in the fo;;owing website but it doesn't seem to help much.
https://support.ptc.com/help/creo/creo_pma/r9.0/usascii/index.html#page/part_modeling/part_modeling/Rules_for_Patterning_Groups.html
Also had a look at CS131620 - see website below but it doesn't seem to apply to release 9.0
https://www.ptc.com/en/support/article/cs131620?language=en&posno=1&q=unpattern%20and%20make%20indep&source=search&_gl=1*lb9m8o*_ga*MTk4NjQyMTY4OC4xNjkxNjk2NDI5*_ga_CBN5QVB9VJ*MTY5NzQ0Mjk0MS4xNC4xLjE2OTc0NDI5NTkuMC4wLjA.*_ga_1QBT6P6HR1*MTY5NzQ0Mjc4NC4zMi4xLjE2OTc0NDI5NTkuNDIuMC4w
hhillerAnswer
This in an enhancement.
 Workaround: make a group and pattern the group. Then unpattern is available. This workaround does not work for Geometry Pattern.
See https://www.ptc.com/en/support/article/CS59045
hhiller17-PeridotAnswer
Michael_10-MarbleAuthor
Once you unpattern how do you make the features independent of each other such that you can change their size individually?
Ok I have had more of a look at the Article - CS59045 and found it works with holes but not extruded cuts - see attached part files in the winrar compressed file
