Jonathan_Felipe
update of offset and project commands
hello everyone, could you explain this update of the offset and project commands
In my humble opinion it seems to have gotten worse.
Now I have to confirm the command and before I didn't need to
tbraxton
You are not the only user to experience disappointment with this enhancement. If you find issues not covered by the threads posted by @StephenW , please document them. Post them here and open a call with PTC support. @mneumueller at PTC has been following up on this issue when use cases are clearly documented.
I would think it worthwhile for PTC to map the pre-enhancement selection workflows to the new command and publish that as part of the help files. @mneumueller has been responding to issues in this forum which is great. The convoluted nature of this topic suggests that a quick reference card style document is needed to convey the workflows for different use cases.
