Sep 21, 2022 8:21 AM UTC
Urgent. Remove enable_embedded_component_demo
I tried the hidded function enable_embedded_component_demo in Creo 6 as a means of reducing the number of files/parts created when importing for xample step files. The problem now is that it seems to have "contaminated" the files and I cannot open any files when I turn this function off.
The error I get is "This model ad been created with a Creo 5.0 demo version for embedded components and cannot be retreived"
Furthermore, som components have been worked on and checked into Windchill. So reverting to a previous version is not an option.
Please help!
tbraxton
tbraxtonAnswer
Sep 21, 2022 12:29 PM UTC
You are not the first to have this issue as there is a support article addressing this.
  • Workaround:
    • Open an lower iteration of the assembly which was saved before applying the config option enable_embedded_component_demo to yes
    • To open a lower iteration of file, refer article CS289032
Refer to this article for details:
https://www.ptc.com/pt/support/article/cs306233#:~:text=If%20hidden%20config%20option%20enable_embedded_component_demo%20is%20set%20to,Aplica-se%20a%20Creo%20Parametric%205.0.0.0%20to%205.0.1.0%20Descri%C3%A7%C3%A3o
PTC does not support hidden config options and explicitly warns against using them in a production environment.
StephenW
Sep 21, 2022 11:10 AM UTC
It is highly unlikely other users will be able to help you.
You will need to contact PTC directly (or your VAR). Not sure how much they can help but it's likely your only option.
Sep 21, 2022 11:13 AM UTC
Ok, thanks. Yes, I contacted the support team from our reseller. The only option seems to be to revert back to an earlier version of the files, or delete the new ones made during this period.
tbraxton
tbraxton22-Sapphire IIAnswer
  • Workaround:
20-Turquoise
Sep 21, 2022 9:56 PM UTC
Please help!
Might be good excuse to upgrade to Creo Parametric 8.0 which supports inseparable assemblies:
https://www.ptc.com/en/support/article/cs349444
It would be fairly easy to install a seat of Creo Parametric 8.0 and see if it will open these "contaminated" assemblies.
Sep 22, 2022 7:49 AM UTC
Thanks. Yes, I tried it now in Creo 9 but it wouldn't open. So I've now replaced everything with earlier iterations.
20-Turquoise
Sep 26, 2022 8:42 PM UTC
Seems rather lame that PTC does not support these enable_embedded_component_demo assemblies, in Creo Parametric 8.0 or newer, now that inseparable assemblies are now officially supported. I wonder if that is an oversight or whether some major under the hood changes actually took place between the "demo mode" and the "Creo Parametric 8.0+ real mode".
The UI appears to be very similar if not the same.
Somebody from PTC care to make a comment on this?
