Use Creo parametric to draw a 3D mesh model
I am using Creo Parametric Release 6.0 and Datecode6.0.0.0
人脸3D网格模型绘制,网格边长大小一致且可调,网格的平面形状为四边形
需求:使用creo parametric 绘制人脸3D网格模型,网格边长大小一致且可调,网格的平面形状为四边形或六边形,厚度为40um
Translated by the community team using Microsoft Translator
The face 3D mesh model is drawn, the edge length of the grid is consistent and adjustable, and the plane shape of the grid is quadrilateral
Requirements: Use Creo parametric to draw a 3D mesh model of the face, the edge length of the grid is consistent and adjustable, the plane shape of the grid is quadrilateral or hexagonal, and the thickness is 40um
AndrewK
Community Manager
Hi XW_10134509,
Welcome to the PTC Community!
Thank you for your question.  I’d like to recommend bringing more details and context to your initial inquiry. It also helps to have screenshots, if possible, to better understand what you are trying to do in your process.
