Use sketch from one part, in another part
Hi, You guys probably do this all the time, but at the moment I model 2 parts that need to fit into each other independantly from one another. If I make changes on one part I have to update the other manually to suit. Is there a way you can copy a sketch from a part (an outline of the part for example) into another part, but for this sketch to update in the new part if you change it in the original part? You can then use this sketch in the new part to offset lines to create an outline on the new part, and you could see whether it was going to fit as you modeled the new part.
