Using colors to distinguish cast -vs- machine features
  • May 15, 2012
  • 3 replies
  • 2540 views
In Wildfire 4 and early, we use colors to distinguish between cast -vs- machine features using the following instructions. I have not been able to find the equivalent functionality in Creo 2.0. Do any of you do the same or know how this could be done inCreo 2.0?
1. Create the cast.prt
2. Create the mach.prt
INSERT - SHARED DATA - MERGE/INHERITANCE
OPEN
OPEN
CONSTRAINT TYPE - DEFAULT
OK
3. To show machined features in color:
Setup colors immediately after the Inheritance Feature.
VIEW - COLOR AND APPEARANCES
Select desired color for machined features.
Select Part under Assignment.
The Assignment tab is missing in the Creo Appearance Managerso you cannot select Part or Surfaces for the desired color.
APPLY
Select desired color for casting.
Select Surfaces under Assignment.
Select a surface on the model.
Right click on the model and select Solid Surfaces.
OK
APPLY
The casting will be shown in one color and all added machined
features will be shown in a different color.
4. Continue developing both the casting and machining "concurrently";
adding material in the <cast>.prt and adding machined features in
the <mach>.prt.
Chris3
The method you describe below doesn't automatically color new features
of the cast part (base). New features show up as same color as the
machined part.
To duplicate this effect, all you have to do is roll back the model tree
to the inheritance feature and then color all of the surfaces one color.
The easiest way to do this is to select "surfaces" from the selection
filter in the lower right hand corner of the window and then use the
find tool (Ctrl F) and search for all surfaces under the history tab.
Then you can color the part another color and you will get the same
effect.
Chris
This communication, including any attachments, consists of non-public
information that is intended solely for use of the individual or entity
to which it is addressed. It is a confidential communication that may
contain information that is proprietary, privileged, export-controlled
and/or exempt from disclosure under applicable U.S. and non-U.S. law.
If the reader is not the intended recipient, or agent responsible for
delivering the message to the intended recipient, please notify the
sender immediately by reply e-mail and delete the communication,
including any attachments, from your system without saving any
information or making any physical copies. Unauthorized use,
dissemination, distribution or copying of this communication, including
any attachments, is strictly prohibited.
What I have always done is to create the casting and then merge that as the first feature int o the machining (however you like... merge is my preference, but I have also done publish geometry copies or inheritances...). Then you "paint the outside" of the casting by COLORS - SURFACES, select one surface, RMB and select SOLID SURFACES, hit okay, and then APPLY. Typically,I'll set the part color to something like bright blue, and then paint the outsidedark green ora pair like this. Then when you create your machined features the resulting surfaces will show up in the PART color. IF the casting changes, you just need to pull the insert mode back to right after the merge, repaint the outside and resume all...
Just another method...
Paul,
Good to hear someone is also using the "Merge" process rather than the Inheritance. 🙂
We don't want the ability for features to be changed independently from the original cast model. Like you said, it's just a different method and each have their pros and cons.
I have not used your coloring tip, so I learned something today.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
