Using Feature ID in Relations
I want to use features ID's to create a note Parameter in a framework part.
Example:
IF EXISTS('FID_1744')
   TESTNOTE = 'TESTING123'
ENDIF
Is there a way to use feature id like this?
pausobAnswer
are you asking whether you can use relations to do something depending on whether a particular feature exists?
If so, I think you might have to use Pro/PROGRAM methods.
Patriot_1776
Syntax looks wrong.  Normally you have an embedded parameter in a feature, like if you save a measurement as a feature.  So, you need BOTH the parameter (i.e. LENGTH) AND the FID.  Also, the ' symbol looks out of place.  Maybe for programming you need them, but in relations I've never seen them.  I'm not an expert in programming in Creo though.
pausob19-TanzaniteAnswer
