Dec 11, 2017 1:49 PM UTC
UV Line on a point
I am trying to create a UV line on a predefined point on a surface.  The reason is to move a hole along the curvature of the part at a specific point.
Thank you
2-Explorer
Dec 11, 2017 7:08 PM UTC
"UV" is a coordinate system that is normalized for a surface. You can create an axis that is normal to a surface at a point.
Dec 14, 2017 3:13 PM UTC
What I want to do use a coordinate (point) that falls on the surface.  Then run a UV line thru that exact point on the surface.  Not trying to make an axis.
2-Explorer
Dec 14, 2017 3:39 PM UTC
What are you calling a UV line?
