variable text in patterns / follow up
  • August 14, 2013
  • 2 replies
  • 1150 views
Here is what I have so far, forgot to attach PDF on original post.
Jscott
I would try a two-direction pattern (Ctrl-select the X and Y coordinate dimensions) and then a single relation of the form
id_label = itos( 401 + 8*x_coord/x_pitch + y_coord/y_pitch )
This assumes that you ultimately set x_coord and y_coord to zero for the ‘401’ instance, although it will probably be easier to build the model with them set to non-zero values initially.
See attached – there’s a negative in the relation because I initially sketched the y coord upwards instead of downwards, so it increments by -10 instead of +10.
HTH...
Jonathan
jlippeth1-VisitorAuthor
Thanks to Jonathan I have made good progress.
Now I would like to understand using the relation editor.
“Pattern using Dimensions, Define increment by relation”
The Help document has one example, I need more.
See attached PDF for available options.
Jscott
