8-Gravel
VBAPI: assemble components to coordinates
how can I assemble components to coordinates like x,y,z and Rx,Ry,Rz and set the constraint to fixed with the VBAPI?
Do I need to use IpfcTransform3D? I can't get it to work.
A different approach could be adding a coordinate system with such kind of coordinates and constrain the component to this csys, delete the constraint and set one to fixed.
I'd like to have the same functionality adding components like in the PDMLink structure tab and editing the coordinate values within excel for automating a huge assembly structure.
I have working code from the examples for assembling components to default or setting different constraints.
I would really appreciate it If you can you help memoving the components.
Thanks!
David
18-Opal
Ok - Shameless plug here... (because it is nearly 100% what you are looking for using Coordinate Systems)
Here are a few examples of how Nitro-CELL does it (from excel):
Assemble Model
Assemble Model Wildcard
Assemble All Root Model Wildcard
AssembleAll Model Wildcard
AssembleAllRoot Model Multi-Wildcard
THAT being said - I *think* you are on the right general path... However, I don't know why you would want to just add models in space...  Typically, assembly operations have purpose (e.g. assemble components to skeleton / sub-skeleton, etc.)
Hope this inspires a bit... or encourages a different approach.
Dave
Spiff8-GravelAuthor
8-Gravel
Hi Dave,
thanks for your answer.
Nitro-CELL actually seems to be a JAVA tool that has an interface to Excel.
And from what I saw they also use the approach to assemble on existing coordinate systems as you also said.
That would just be a workaround because I don't want to have several csys and the constraints in the model so I need to add them, define the constraints and delete them. It would be nicer to just add the component into the group, move them to where they supposed to be and set them fixed.
The general purpose of this is that constraints for top level assemblies are oldschool 🙂
No, just in our case. We have several same top level assemblies just sitting on different positions and therefore we are now switching from classic constraints to position definition via the PDM system which is Windchill PDMLink in our case. For controling assembly positions within Windchill they must be set to fixed and may not have any other constraints.
David
6-Contributor
Hi!
Did you achieve it?
I'm having the same problem, I will appreciate if you can help me.
Thank you
