viewable of Tables which are implemented as a 3D Annotation on a drawing file
Creo has since creo 11 the possibility to use tables as an annotation in a 3D Model and to show them on combined states. The issue is you cant show these tables directly in a 2D drawing files, so you have to copy the table on the harddisk and then to reimport it in the drawing file without a depenmdence. The idea is it that if there are tables shown on combined states that they can be also shown like normal dimensions and symbols on drawing in an associative way. so that if someone edite the table in the model the drawing will show an updated version.
Please repost this idea to the Creo Parametric Ideas forum, which has a few questions to answer as to the reasons and application of the idea.
Thanks for the information have now posted it in the correct Forum.
