VSS with trajpar
  • October 29, 2014
  • 16 replies
  • 7185 views
Creo 2, M120
I have a VSS where I need the value of one radius to vary along the sweep from 100 at the start to 25 at half way back to 100 at the end.  Can I do this with a relation and trajpar?  If needed, I could split it into 2 sweeps where one went from 100 to 25 and the next from 25 to 100.
Is there a fully defined tutorial, or technical document, on trajpar?
MPL
Hi Doug,
Yes, you can do it with a relation and trajpar. It is easiest if it is
one equation:
R = 300*trajpar^2 - 300*trajpar + 100
Is an example of a parabola that will do what you want (R is the radius
dimension).
I believe you can use IF statements to make a non-continuous curve but I
have never done this before.
If you want to do an arbitrary curve, you can use the "evalgraph" function
so that the radius is read off a sketched graph as a function of trajpar.
I can give some instructions on this if you need it.
Mark von Huben
Principal Mechanical Engineer
Cochlear Ltd
1 University Ave
Macquarie Park, NSW, 2113
Australia
p +61 2 9425 5210
I would also recommend looking at driving it by a "graph". Either way work great.
Tim McLellan
Mobius Innovation and Development, Inc.
Trajpar has always been kind of a mystery to me. I know that you (WE) can do
marvelous things using trajpar. But how do we know, or learn, how to use it?
Michael P. Locascio
This is great, thanks.  Can you help me dissect this a bit because I'm realizing that the values that I need may be different than 25 & 100.  How would I adapt this to different values?
Also, I'm realizing that if it's a linear progression for high to low to high I'll likely get a peak / valley in the center, so perhaps a graph would be more appropriate.
This is what I was asking for. Is there any kind of trajpar training course?
I REALLY want to become more of an "expert" with this.
Michael P. Locascio
Sounds like a graph-driven VSS might be best for your application.
A sample Creo 2 model is attached (resume all features).
A critical part of the process is to enter a sketch relation, such as the following:
sd3=evalgraph("GRAPH_1", trajpar*100)
PTCU used to have a section on driving VSS's with trajpar/graphs; ... look for the "Surfacing using Creo Parametric 2.0" course, and the section on
"Using Trajpar and Datum Graphs with Sweep Surface features".
Terry Partridge
Hi Doug,
Did Terry's model give you enough of a hint (Thanks Terry!)? To get the
equation I just started with the equation for a parabola, y = ax^2 + bx +
c and solved for a, b and c so it went through (0,100), (0.5, 25) and (1,
100) where x = trajpar and varies from 0 to 1 along the origin curve (from
start to finish, however you have defined that).
If you find the the VSS feature isn't generating for some reason,
sometimes it is because your sketch can't be resolved at all places along
the curve (. An easy way to check this is to place a datum point along
your origin curve and then placing the VSS sketch on that point.
You can then move the datum point up and down the curve and look at the
sketch at each location to see what is going on. I have done this to
Terry's file and reattached it here (in the group evalgraph_method).
It occurred to me that there was another way to do what you wanted with
datum curves (easiest to directly sketch to the curve or you can use the
second curve to drive a dimension) - an example is the "curve_method"
group. Create as many curves as you want to get the desired geometry. VSS
is very powerful - you are only limited by your imagination!
Should you need to have the edge of a VSS tangent to a curved surface and
ProE decides it can't do it automatically, there are ways to cheat if you
are happy with "close enough to tangent is good enough". If needed I can
find an example but it will take quite some time to remove confidential
info / genericise the model. I can't do this today.
cheers
Mark von Huben
Cochlear Ltd
1 University Ave
Australia
p +61 2 9425 5210
Actually, I got something workable (for now) without trying it.  I’ll need to come back to it later, but I’ve got other fires to fight first.  I definitely appreciate the input and have files the emails away for that inevitability.
I particularly liked this bit:
“I just started with the equation for a parabola, y = ax^2 + bx + c and solved for a, b and c so it went through (0,100), (0.5, 25) and (1, 100) where x = trajpar and varies from 0 to 1 along the origin curve”
Of course, why didn’t I think of that? 😛
So, if I needed values of A & B instead of 25 & 100, I need to re-solve for the points (0,A), (0.5,B) and (1,A), correct?  This assumes that I can dust off my long dormant Algebra skills and figure that out. 😕
While breaking out the Algebra book can work, you may wish to try a solve block:
SOLVE
d1 + d2 = 500
d1 - d2 = 0
FOR d1 d2
You can substitute your own functions.
http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/fundamentals/fund_seven_sub/About_Simultaneous_Equations.html
x
