We are using the fix index method for this, but is there a way to do this automatically
Initially posted in this topic
We are facing the same problem. We would like to add all bolts to ID100.. washer to ID200... nuts ID300... We are using the fix index method for this, but is there a way to do it automatically, I have created mapkey that export the table out, fire a script to create ID's , but how can i import/update the table on the drawing?
if you export a table from Creo, you can't import it back and hope it links to an existing repeat region table.
I think you can create 4 repeat region tables:
1st one for manufactured parts
2nd one for bolts
3rd one for washers
4th one for nuts
In these repeat region tables you can set filter to hide unwanted items.
In "bolt" region you can define relation my_index=rpt_index+99 and display &rpt.rel.my_index istead of &rpt.index
Idea: If you are able to "develop" the right relation for my_index, then it would be possible to use only one repeat region.
2nd one for bolts
3rd one for washers
4th one for nuts
