Weblink (CreoJS) Retrieve Table Help
I am looking for any help on the below code.  The pin-out table is not loading in my drawing, and I'm not sure why.
The error is XToolkitGeneralError.
I currenrly have copies of  the pin-out.tbl file in my "pro tables directory", my weblinkexamples folder, and my jscript and html folders under that.  I also tried my work space as well.
The table has two repeat regions, and works fine when I load table from file in parametric.
function createEdgeNote(max /* integer */)
 if (pfcIsMozilla())
 netscape.security.PrivilegeManager.enablePrivilege("UniversalXPConnect");
 Get the current drawing & its background view
 var session = pfcGetProESession ();
 var drawing = session.CurrentModel;
 if (drawing.Type != pfcCreate ("pfcModelType").MDL_DRAWING)
 throw new Error (0, "Current model is not a drawing");
 Interactively select a Edge in a drawing view
 var noteedge = pfcCreate ("pfcSelectionOptions").Create ("edge");
 if (max != "UNLIMITED")
 noteedge.MaxNumSels = parseInt (max);
 session.CurrentWindow.SetBrowserSize (0.0);
 var selections = void null;
 try {
 selections = session.Select (noteedge, void null);
 catch (err) {
 if (pfcGetExceptionType (err) == "pfcXToolkitUserAbort" ||
 pfcGetExceptionType (err) == "pfcXToolkitPickAbove")
 return (void null);
 else
 throw err;
 if (selections.Count == 0)
 return (void null);
for (var i = 0; i < selections.Count; i ++)
 var seledge = selections.Item (i);
 var String_line1 = "LABEL: &REF_DES:ATT_CONN";
 var String_line2 = "TO ";
 var LABEL = String_line1 + "\n" + String_line2;
 var name = String(LABEL)
 Allocate a text item, and set its properties
 var text = pfcCreate ("pfcDetailText").Create (name);
 Allocate a new text line, and add the text item to it
 var texts = pfcCreate ("pfcDetailTexts");
 texts.Append (text);
 var textLine = pfcCreate ("pfcDetailTextLine").Create (texts);
 var textLines = pfcCreate ("pfcDetailTextLines");
 textLines.Append (textLine);
 Set the location of the note text
 var dwgView = seledge.SelView2D;
 var outline = dwgView.Outline;
 var textPos = outline.Item (1);
 // Force the note to be slightly beyond the view outline boundary
 textPos.Set (0, textPos.Item (0) + 0.01 + i * (textPos.Item (0) -
					 outline.Item (0).Item(0)));
 textPos.Set (1, textPos.Item (1) + 0.01 + i * (textPos.Item (1) -
					 outline.Item (0).Item(1)));
 var position = pfcCreate ("pfcFreeAttachment").Create (textPos);
 position.View = dwgView;
 Set the attachment for the note leader
 var leaderToEdge = pfcCreate ("pfcParametricAttachment").Create (seledge);
 Set the attachment structure
 var allAttachments = pfcCreate ("pfcDetailLeaders").Create ();
 allAttachments.ItemAttachment = position;
 allAttachments.Leaders = pfcCreate ("pfcAttachments");
 allAttachments.Leaders.Append (leaderToEdge);
 Allocate a note description, and set its properties
 var instrs = pfcCreate ("pfcDetailNoteInstructions").Create (textLines);
 instrs.Leader = allAttachments;
 Create / Show Pin Out Tables
try
var tableinstr = pfcCreate("pfcTableRetrieveInstructions").Create("pin-out" , position);
var dwgTable = drawing.RetrieveTable (tableinstr);
if (dwgTable != null) {
 dwgTable.Show();
} else {
} catch (err) {
 alert("Error creating pin-out table: " + pfcGetExceptionDescription (err));
 Create / Display the note
var note = drawing.CreateDetailItem (instrs);
note.Show ();
 return (selections);
Hi AH,
Now the standard embedded browser is Chromium, it depends on what Creo Parametric you are using, I think, this could be the problem...
Look at this thread
Catalina
Community Manager
Hi @AH_10565398,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina | PTC Community Manager
