Weld order
After using the weld module to create welds i have run into a problem.
When showing the respective symbol on the drawing the tail is populated by the weld order. I don´t seem to be able to change the order manually and more importantly i can´t remove it completely.
Anyone know of a solution ? As it is now i have to add the symbols manually as i can´t get rid of the ordering.
tbraxton
Have you attempted the technique outlined in this article?
https://www.ptc.com/en/support/article/CS43996
I was hoping there was a quicker way than redoing the entire standard library 😞
