Sep 11, 2014 1:12 PM UTC
When changing units, model disappears
Creo 2.0
Have an assembly made of imported parts and when I try to change the model from inches to metric it disappears. I can replicate with by changing one part or the whole asm. I have also tried to convert units and interpret units and get the same results. Any ideas?
TomU
TomUAnswer
Sep 13, 2014 3:54 AM UTC
It is caused by importing models that are supposed to be Creo files (.prt, .asm, etc.) but were generated with something other than Creo. DO NOT USE THESE! Either use neutral files instead (STEP, IGES, etc.), or create your own neutral file (from this assembly) and reimport it.
Patriot_1776
Sep 11, 2014 2:04 PM UTC
...did you divide by zero?
Sep 11, 2014 5:21 PM UTC
Have a look at part accuracy. I think it can be inherited. If you want to upload the file, we can have a look. Use the advanced editor.
And welcoem to the forum, Casey.
TomU
TomU23-Emerald IVAnswer
TomU
Sep 17, 2014 7:28 PM UTC
Casey, did this help or are you still having the issue?
cgavette1-VisitorAuthor
Sep 18, 2014 11:14 AM UTC
Yes, thank you!
