when I click on the plane or in a face of a part, the software starts a process of regenerate and locks the software. How to configure the creo to avoid regenerate every time I select a plan or a face of a part?
It's likely simply a video card problem. You can test if it is a video issue by adding the following to your config.pro file using a text editor and restart Creo.
graphics win32_gdi
If that solves the issue, it is definitely a video card issue. You can try updating your video card drivers and remove that line from the config.pro file.
