8-Gravel
May 22, 2024 9:23 AM UTC
when you are into asm and you want open a drw of part you can with the macro or not?
Hi
I have a question, when you are into asm and you want open a drw of part you can with the macro or not? because if I try to open a drw of prt not open a prt but open the drw of asm
Thank You
May 22, 2024 11:14 AM UTC
step no. 1 ... select part in Model tree, RMB and open part in separate window
step no. 2 ... open part drawing using mapkey
Emeritus
May 29, 2024 10:33 AM UTC
Hello @Daniel82,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
