Which enhancements of Creo 4.0 do you like best?
  • December 17, 2016
  • 7 replies
  • 5077 views
I think Creo 4.0 is a very classic big release than Creo 3.0, the following enhancements are I like top ten:
  • Box- selection - available in part mode and assembly, very convenient and effective
  • New Mini Toolbar- Direct command access from Mini Toolbar and dual context support
  • Flexible modeling extension added into sheetmetal and simulate
  • Sketch snapping to model entities- without explicit projection
  • Style G3 (Acceleration) Connections
  • Assembly new Booleans - Many to many
  • 3D Sweep
  • Mid-plane
  • Full screen
  • File names Support for double-byte characters
You can review full list from https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS236243
Other good news, refer to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS251133, Creo 4.0 M010 will support AR and Creo 4.0 M020 will support IOT
Does filenaming in Creo Parametric 4.0 allow for longer names than 31 characters? Does it allow spaces, forward slashes, dots and other sorts of chars?
I guess I should just install it and try it out.
2-Explorer
December 17, 2016
The better question is: does Windchill x support these characters in names?
Good question. I imagine Windchill will require upgrade.
3-Newcomer
December 18, 2016
I just like geometry search tool in flexible modeling, set line thickness in sketch, new material library including about 100 material and new cross-section hatch library
3-Newcomer
December 19, 2016
just like the 3D Sweep. but need to half year for Creo 4.0 M020
2-Explorer
December 20, 2016
The following new is very good, also wait for many many year ago
  • file name support Chinese
  • Datum Feature Symbol
  • mid-plane
  • full screen
