Sep 30, 2015 10:58 AM UTC
whole working directory got corrupted.
I tried to create a drawing pdf and it showed an error that the pdf cannot be created and then the drawing and its part got corrupt.
Creo gives a message cannot retrieve the file.
the computer I am using is in network.
Has anybody faced this issue before?
Operating system windows 7 professional sp1
Creo Parametric 2.0 M100
Sep 30, 2015 12:54 PM UTC
Can you open an older iteration?  If you haven't purged your directory, you should have several iterations available.  On rare occasions I have seen this, usually when Creo crashes during a save operation.  I've always been able to open a previous iteration, however.
Sep 30, 2015 12:58 PM UTC
unfortunately i did purge the directory
Sep 30, 2015 1:06 PM UTC
Ugh, that's a shame.  If you have maintenance, I'd send it to PTC.  They may be able to recover it.
