Why cant I see user created saved views and sections in Creo View Lite?
  • January 18, 2017
  • 1174 views
In Creo Parametric 3.0 m30 a user creates a named view other than FRONT, RIGHT or TOP and then creates a section called A.
I would expect both of those to be listed when the model is opened in CREO View Lite.
Is there a recipe file edit or something to make those available to CREO View?
wrsamuels14-AlexandriteAuthor
ok, halfway there...found out that changing the 0 to 1 in the line adapter/outputAuthorState=0 allowed named views to be exported.
I suspect there is another line or something to export sections or combined states with sections.
If you know the answer please share.
