Apr 17, 2015 12:13 PM UTC
Why weld is blue?
My default color of welding is orange, but in this case weld appears blue.
What does it means?
In picture i used a "Butt weld", side 1 chain and side 2 surface.
StephenW
Apr 17, 2015 12:47 PM UTC
Blue usually indicates a surface instead of a solid.
Apr 17, 2015 12:48 PM UTC
Luca,
weld is created as Surface feature. "Blue" color is default color of surface features. I hope you can assign any color to weld surfaces.
Martin Hanak
lnessi1-VisitorAuthor
Apr 17, 2015 1:16 PM UTC
Why Creo use surface and not solid welding?
It's just because it can't connect the two sides with a solid feature or maybe is mine setting?
Apr 17, 2015 1:37 PM UTC
Luca,
it looks like weld is always created as a surface. See welding in pro e wildfire 5.
Martin Hanak
